Ga door naar hoofdinhoud
Fujitsu LIFEBOOK P7010D Monitor Replacement
Wat je nodig hebt
  1. Fujitsu LIFEBOOK P7010D Monitor Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the laptop upside down on a table.
  2. Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 2, afbeelding 1 van 1
    • Locate the battery (the grey block). Find the two tabs on one end of the battery near the side of the laptop.
    • Using your fingers, press both tabs down at once until they are fully depressed.
  3. Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 3, afbeelding 1 van 1
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
  4. Fujitsu LIFEBOOK P7010D Monitor Replacement, Keyboard: stap 4, afbeelding 1 van 2 Fujitsu LIFEBOOK P7010D Monitor Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Unscrew three 2.4mm and one 5.7mm screws using a Phillips # 0.
    • Unscrew three 1.9mm screws in the battery compartment still using a Phillips # 0
  5. Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 5, afbeelding 1 van 3 Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 5, afbeelding 2 van 3 Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 5, afbeelding 3 van 3
    • Mind the wire connections on the bottom right side of the monitor. They are still connected between the monitor and computer.
    • Raise the monitor as you normally would until it pops out by itself. Rotate the left side up and to the right to unhook hinges that may catch on the computer.
    • Lay the monitor flat next to the computer.
  6. Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 6, afbeelding 1 van 2 Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Using a smaller spudger (like a PX3688), pivot the sound case out above the "F2" and "Insert" buttons.
    • Lift the case out and set it aside.
    • For the proceeding steps, put on your anti-static wrist strap and attach the metal clip to something metal and grounded in order to protect the delicate circuitry inside the computer.
  7. Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 7, afbeelding 1 van 3 Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 7, afbeelding 2 van 3 Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 7, afbeelding 3 van 3
    • Using the same spudger, pry the top of the keyboard up above the "F2" key.
    • Turn the computer so that the bottom is facing you.
    • The keyboard is connected to a black plastic strip, slowly pull the keyboard and place it to the side.
  8. Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 8, afbeelding 1 van 2 Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the keyboard by gently pulling on the hard plastic square straight up from the white connector.
  9. Fujitsu LIFEBOOK P7010D Monitor Replacement, Monitor: stap 9, afbeelding 1 van 3 Fujitsu LIFEBOOK P7010D Monitor Replacement, Monitor: stap 9, afbeelding 2 van 3 Fujitsu LIFEBOOK P7010D Monitor Replacement, Monitor: stap 9, afbeelding 3 van 3
    • Peel the white tape from the wires connected to the monitor, but do not completely remove it.
    • Unplug the white and black wires with your fingers.
  10. Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 10, afbeelding 1 van 3 Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 10, afbeelding 2 van 3 Fujitsu LIFEBOOK P7010D Monitor Replacement: stap 10, afbeelding 3 van 3
    • Unplug the white chip connected to the thicker wire with two smaller spudgers (like a PX3688) by wiggling it back and forth until it pops out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nicholas Ross
186 Reputatie
7 handleidingen geschreven
Cal Poly, Team 10-31, Amido Winter 2012 Lid van Cal Poly, Team 10-31, Amido Winter 2012
CPSU-AMIDO-W12S10G31
5 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 2,791
