Wat je nodig hebt
Push the tab down as far as possible using your finger or plastic opening tool to unlock the disc drive.
While still holding the tab down, use your other hand to pull out the disc drive straight out of its place.
On the bottom of the laptop, find the bottom-plate screw holes. They are located near the disc drive. Parallel to them is a 2.4mm screw.
After locating the 2.4mm screw, use a Phillips #0 screwdriver to unscrew.
3 andere personen hebben deze handleiding voltooid.
