Ga door naar hoofdinhoud
Fujitsu LifeBook U810 Wireless LAN card Replacement
Wat je nodig hebt
  1. Fujitsu LifeBook U810 Wireless LAN card Replacement, Wireless LAN card: stap 1, afbeelding 1 van 3 Fujitsu LifeBook U810 Wireless LAN card Replacement, Wireless LAN card: stap 1, afbeelding 2 van 3 Fujitsu LifeBook U810 Wireless LAN card Replacement, Wireless LAN card: stap 1, afbeelding 3 van 3
    • Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver.
  2. Fujitsu LifeBook U810 Wireless LAN card Replacement: stap 2, afbeelding 1 van 3 Fujitsu LifeBook U810 Wireless LAN card Replacement: stap 2, afbeelding 2 van 3 Fujitsu LifeBook U810 Wireless LAN card Replacement: stap 2, afbeelding 3 van 3
    • Remove the two 5mm screws with a Phillips #0 screwdriver.
    • Remove the wireless LAN card from the device.
  3. Fujitsu LifeBook U810 Wireless LAN card Replacement: stap 3, afbeelding 1 van 2 Fujitsu LifeBook U810 Wireless LAN card Replacement: stap 3, afbeelding 2 van 2
    • Detach the two antenna cables connected to the wireless LAN card by gently pulling them out of place.
Conclusie
Anne Kutt
197 Reputatie
1 Handleiding geschreven
UC Davis, Team S4-G7, Lore Fall 2018 Lid van UC Davis, Team S4-G7, Lore Fall 2018
UCD-LORE-F18S4G7
3 Leden
4 handleidingen geschreven
Één opmerking
Is there a BIOS whitelist for this machine? I wanted to replace my wifi card due to OS incompatibility but I've seen conflicting reports.
Adam Birnbaum - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 635
