Inleiding
Replacing the battery for the Fujitsu Lifebook U810 is a simple process that does not require a toolkit of any kind. This guide helps repair a short battery life for the device and can improve the overall lifespan. You can find a new battery online by searching the model number and corresponding part for the U810 model.
  1. Flip the Lifebook so it's underside is showing and you see a small latch with the lock symbol on the right side. Flip the Lifebook so it's underside is showing and you see a small latch with the lock symbol on the right side. Flip the Lifebook so it's underside is showing and you see a small latch with the lock symbol on the right side.
    • Flip the Lifebook so it's underside is showing and you see a small latch with the lock symbol on the right side.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Push the latch to the right to release the battery.
    • Push the latch to the right to release the battery.
  4. Hold the latch in the unlocked position and with your other hand pull the battery straight out from the back of the device. Hold the latch in the unlocked position and with your other hand pull the battery straight out from the back of the device. Hold the latch in the unlocked position and with your other hand pull the battery straight out from the back of the device.
    • Hold the latch in the unlocked position and with your other hand pull the battery straight out from the back of the device.
Conclusie
Emmy Hughes
147 Reputatie
1 Handleiding geschreven
UC Davis, Team S4-G7, Lore Fall 2018 Lid van UC Davis, Team S4-G7, Lore Fall 2018
UCD-LORE-F18S4G7
3 Leden
2 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 4
Altijd: 39
