Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the camera upside down to locate the battery compartment.
Slide the button up to open the compartment.
Slide the orange button up to release the battery.
Twist the lens cap to remove it from the camera.
Remove the six 6.5 mm Phillips screws from the front of the lens assembly.
Use tweezers to remove the top metal ring and the thin metal ring below it .
Remove the four 4.3 mm Phillips screws inside the lens assembly.
Remove the six 2.5 mm Phillips screws from the bottom of the camera.
Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
Remove the 3.4 mm Phillips screw.
Remove the 3.7 mm screw.
Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
Remove the 3.2 mm Phillips screw.
Remove the 3.8 mm Phillips screw.
Remove the 2.8 mm Phillips screw.
Use tweezers to slide the metal shield straight out of the external flash mount.
Remove the four 4.6 mm Phillips screws from the external flash mount.
Use tweezers or two fingers to remove the mount clip.
Extend the LCD.
Remove the two black 4.3 mm Phillips screws from the back case.
Use two fingers to peel back and remove the black plastic cover from behind the LCD.
Slowly pull the back frame away from the camera.
Use tweezers to pull the white and blue ribbon cable out of the connector.
Slide the frame around the LCD to remove it from the camera.
Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
Use tweezers to unhook the speaker near the left handgrip.
Slowly lift the metal frame away from the motherboard.
Use tweezers to remove the plastic covering the motherboard.
To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
Remove the back case.
Remove the four 2.6 mm Phillips screws from the LCD hinges.
Tilt the LCD away from the metal frame.
Use two fingers to pull the ribbon through the hole in the metal frame.
Remove the LCD from the metal frame.
Use the pointed end of a spudger to remove the ribbon cover on the back of the LCD.
Remove the two 2.6 mm Phillips screws from the right hand side of the LCD screen.
Remove the two 2.6 mm Phillips screws from the left hand side of the LCD screen.
Use a plastic opening tool to pry the LCD case open.
Once the case is open, pull the ribbon through the hole on the back case.
Één andere persoon heeft deze handleiding voltooid.
