Inleiding
In this guide you will need two tools: a Phillips #00 screwdriver and a soldering iron. Take caution when taking out the bulb especially if the capacitor is in tact, you may get shocked if you touch it.
Wat je nodig hebt
Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
Once the shell is off, remove the one 6.5 mm screw that is attached to the flash bulb using a Phillips #00 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
3Gids Commentaar
Hi, does anyone know how to find replacement bulb?
same question here!
Hi, I did bulb replacement on Mini 40 with the help of this guide. I found similar looking bulb on Aliexpress. I suggest you to look online for a replacement xenon tube lamp that is similar in look and length. I found lamp for Nikon models ******D40 D40X D60 D60X D3000 fitting and working fine with Instax Mini 40
