Ga door naar hoofdinhoud
Fujifilm Instax Mini 8 Flash Unit Replacement
Wat je nodig hebt
  1. Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: stap 1, afbeelding 1 van 2 Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: stap 1, afbeelding 2 van 2
    • You start off with the camera.
  2. Fujifilm Instax Mini 8 Flash Unit Replacement: stap 2, afbeelding 1 van 2 Fujifilm Instax Mini 8 Flash Unit Replacement: stap 2, afbeelding 2 van 2
    • Open up the back and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Flash Unit Replacement: stap 3, afbeelding 1 van 2 Fujifilm Instax Mini 8 Flash Unit Replacement: stap 3, afbeelding 2 van 2
    • Remove the two Phillips #00 screws from the bottom of the camera.
    • Remove the two screws on the side of the camera.
    • Additionally, there are two screws in the battery compartment which also need to be removed.
  4. Fujifilm Instax Mini 8 Flash Unit Replacement: stap 4, afbeelding 1 van 3 Fujifilm Instax Mini 8 Flash Unit Replacement: stap 4, afbeelding 2 van 3 Fujifilm Instax Mini 8 Flash Unit Replacement: stap 4, afbeelding 3 van 3
    • Once all screws are removed, gently pry open the front casing with your hands or a prying tool.
    • There will be a spring that attaches the front casing and the main circuit board, so take care as to not break the spring.
  5. Fujifilm Instax Mini 8 Flash Unit Replacement: stap 5, afbeelding 1 van 1
    • You should now be able to see the flash unit. Take care to not touch the large black capacitor on the top. It will still have a charge and will hurt.
  6. Fujifilm Instax Mini 8 Flash Unit Replacement: stap 6, afbeelding 1 van 2 Fujifilm Instax Mini 8 Flash Unit Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the two screws attaching the flash to the main circuit board. The flash unit will detach away from the motherboard, now leaving just the connecting wires to remove next.
  7. Fujifilm Instax Mini 8 Flash Unit Replacement: stap 7, afbeelding 1 van 3 Fujifilm Instax Mini 8 Flash Unit Replacement: stap 7, afbeelding 2 van 3 Fujifilm Instax Mini 8 Flash Unit Replacement: stap 7, afbeelding 3 van 3
    • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Bo W
1.037 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-1, Meier Fall 2015 Lid van USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Leden
26 handleidingen geschreven
10Gids Commentaar
Where can I purchase the flash unit?
Casey Sanders - Antwoord Deel
Hi, did you ever find out where to replace the flash light unit?
Rachel Street - Deel
Why is all the camera lights flashing red and doesn't work?
medgabby - Antwoord Deel
Will the camera work without any flash, or are the connections required for the whole thing to function ?
Hyaku Gen - Antwoord Deel
Where can I find the flash unit to purchase??
Maria - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 139
Altijd: 37,145
