Ga door naar hoofdinhoud
Fujifilm Instax Mini 8 Capacitor Replacement
Wat je nodig hebt
  1. Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: stap 1, afbeelding 1 van 3 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: stap 1, afbeelding 2 van 3 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: stap 1, afbeelding 3 van 3
    • First, push in the lens and remove the two AA batteries.
    Vraag FixBot
    Voeg opmerking toe
  2. Fujifilm Instax Mini 8 Capacitor Replacement: stap 2, afbeelding 1 van 2 Fujifilm Instax Mini 8 Capacitor Replacement: stap 2, afbeelding 2 van 2
    • Open the rear compartment and remove the film cartridge.
    Vraag FixBot
    Voeg opmerking toe
  3. Fujifilm Instax Mini 8 Capacitor Replacement: stap 3, afbeelding 1 van 3 Fujifilm Instax Mini 8 Capacitor Replacement: stap 3, afbeelding 2 van 3 Fujifilm Instax Mini 8 Capacitor Replacement: stap 3, afbeelding 3 van 3
    • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera. Additionally, there are two screws in the battery compartment which also need to be removed.
    Vraag FixBot
    Voeg opmerking toe
  4. Fujifilm Instax Mini 8 Capacitor Replacement: stap 4, afbeelding 1 van 3 Fujifilm Instax Mini 8 Capacitor Replacement: stap 4, afbeelding 2 van 3 Fujifilm Instax Mini 8 Capacitor Replacement: stap 4, afbeelding 3 van 3
    • Once all screws are removed, gently pry open the front casing with your hands or plastic opening tools carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
    Vraag FixBot
    Voeg opmerking toe
  5. Fujifilm Instax Mini 8 Capacitor Replacement: stap 5, afbeelding 1 van 3 Fujifilm Instax Mini 8 Capacitor Replacement: stap 5, afbeelding 2 van 3 Fujifilm Instax Mini 8 Capacitor Replacement: stap 5, afbeelding 3 van 3
    • Locate the photo-flash capacitor, then find all the connecting wires to the motherboard and battery compartment. Take notes to which exact wires they are to limit mistakes.
    Vraag FixBot
    Voeg opmerking toe
  6. Fujifilm Instax Mini 8 Capacitor Replacement: stap 6, afbeelding 1 van 3 Fujifilm Instax Mini 8 Capacitor Replacement: stap 6, afbeelding 2 van 3 Fujifilm Instax Mini 8 Capacitor Replacement: stap 6, afbeelding 3 van 3
    • Carefully pry out the capacitor with a spudger or plastic opening tools.
    Vraag FixBot
    Voeg opmerking toe
  7. Fujifilm Instax Mini 8 Capacitor Replacement: stap 7, afbeelding 1 van 3 Fujifilm Instax Mini 8 Capacitor Replacement: stap 7, afbeelding 2 van 3 Fujifilm Instax Mini 8 Capacitor Replacement: stap 7, afbeelding 3 van 3
    • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Bo W
1.037 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-1, Meier Fall 2015 Lid van USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Leden
26 handleidingen geschreven
3Gids Commentaar
Hi There! I need a new capacitor for my daughter's Fuji Instax Mini 9. Do you supply? I am in South Africa.
Kuschi - Antwoord Deel
Hi, any recommendations on where can find a shop in Kl Malaysia to fix my instax mini 8? Thanks in advance !
Miss.G - Antwoord Deel
Bonjour, j'ai un instax mini 11 qui clignote orange rapidement.
Après divers manipulation de réinitialisation et de changement de pile pour des neuves rien y fait.
Est-ce que ça pourrait être un problème de condensateur qui empêche le flash de charger correctement ? Et mettrais donc l'appareil en erreur ?
Elise Tibbo - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 142
Altijd: 28,626
