Fujifilm Finepix S1000fd Display Screen Replacement
Inleiding
Ga naar stap 1Use caution when going through with the procedure. This procedure involves doing operations near the motherboard of the device, which has many sensitive components.
Wat je nodig hebt
Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
Use a plastic opening tool to lift up the right side of the display screen.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Hi, any idea how i can get to the shutter button mechanism, it’s stopped working and I don’t want to break anything in my impatience to fix it :)
