Ga door naar hoofdinhoud
Fujifilm Finepix S1000fd Battery Replacement
  1. Fujifilm Finepix S1000fd Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the camera upside down.
  2. Fujifilm Finepix S1000fd Battery Replacement: stap 2, afbeelding 1 van 1
    • Flick the switch on the right side of the camera, and bring it downwards, while simultaneously lifting up the cover.
    • While the switch is held down, lift up the battery compartment cover.
  3. Fujifilm Finepix S1000fd Battery Replacement: stap 3, afbeelding 1 van 1
    • Observe that the signs on the battery compartment will show you how to insert the 4 AA batteries.
    • There should be positive battery signs near the bottom slot and the third slot from the bottom.
    • There should be negative battery signs near the top slot and the second slot from the bottom.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Somya Lalwani
113 Reputatie
1 Handleiding geschreven
Cal Poly, Team 8-7, Banghart Winter 2017 Lid van Cal Poly, Team 8-7, Banghart Winter 2017
CPSU-BANGHART-W17S8G7
4 Leden
10 handleidingen geschreven
3Gids Commentaar
My S1000 takes 1 battery not five…
francanadaswan - Antwoord
My Fuji S1000 digital camera takes 1 battery, not five. Where can I get a replacement? Nothing on Amazon.
My s1000fd takes 4 batteries... how would i clean it after the batteries leaked in the battery well? is it salvageable?
Beckmansbabe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 46
Altijd: 1,944
