Inleiding
The shutter button allows for the taking of pictures. This guide will explain how to get to and remove the shutter button and components that are associated with it.
Wat je nodig hebt
Remove the screws from the bottom of the camera using the tri-wing screwdriver.
Three 5.4 mm tri-head screws.
Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
Remove the fifteen 2.9 mm Phillips #00 screws.
Pull on the shutter button display data cable on the end connected to the motherboard until it slides out.
Één andere persoon heeft deze handleiding voltooid.
