Ga door naar hoofdinhoud
Fujifilm Finepix F10 6.3 MP LCD Replacement
Wat je nodig hebt
  1. Fujifilm Finepix F10 6.3 MP LCD Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP LCD Replacement: stap 2, afbeelding 1 van 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP LCD Replacement: stap 3, afbeelding 1 van 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP LCD Replacement: stap 4, afbeelding 1 van 3 Fujifilm Finepix F10 6.3 MP LCD Replacement: stap 4, afbeelding 2 van 3 Fujifilm Finepix F10 6.3 MP LCD Replacement: stap 4, afbeelding 3 van 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP LCD Replacement, LCD: stap 5, afbeelding 1 van 1
    • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
  6. Fujifilm Finepix F10 6.3 MP LCD Replacement: stap 6, afbeelding 1 van 1
    • Slide casing out using the spudger.
  7. Fujifilm Finepix F10 6.3 MP LCD Replacement: stap 7, afbeelding 1 van 2 Fujifilm Finepix F10 6.3 MP LCD Replacement: stap 7, afbeelding 2 van 2
    • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sarah Looper
100 Reputatie
7 handleidingen geschreven
Clemson, Team 13-4, Benson Spring 2013 Lid van Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Leden
16 handleidingen geschreven
3 opmerkingen
Great Guide! Worked great to replace my screen!
Daniel - Antwoord
Awesome guide! BEST WORK I'VE EVER SEEN ON A REPAIR GUIDE
Johnston Thayer - Antwoord
Shutter button replacement was great too!
Daniel -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 963
