Ga door naar hoofdinhoud
Fujifilm Finepix F10 6.3 MP Flash Battery Replacement
Wat je nodig hebt
  1. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: stap 4, afbeelding 1 van 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: stap 4, afbeelding 2 van 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: stap 4, afbeelding 3 van 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Front cover: stap 5, afbeelding 1 van 1
    • Remove screws from motherboard using the Phillips 00 screwdriver.
    • Two 2.5 mm widehead Phillips screws
    • One 3.3 mm #00 Phillips screws
    • Three 2.5 mm #00 Phillips screws (black screws)
  6. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: stap 6, afbeelding 1 van 1
    • Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Remove 3.3 mm #00 Phillips screw from the side of the front screen.
  7. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: stap 7, afbeelding 1 van 2 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: stap 7, afbeelding 2 van 2
    • Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard.
    • Do not be alarmed if it takes substantial pressure to separate the two.
  8. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Flash Battery: stap 8, afbeelding 1 van 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Flash Battery: stap 8, afbeelding 2 van 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Flash Battery: stap 8, afbeelding 3 van 3
    • Gently remove battery from casing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sarah Looper
100 Reputatie
7 handleidingen geschreven
Clemson, Team 13-4, Benson Spring 2013 Lid van Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Leden
16 handleidingen geschreven
Één opmerking
What is the battery number so you can have a replacement ready?
attic77 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 674
