Inleiding
When the camera is non-responsive, the most common issue is a faulty motherboard. This guide will take you through the step of removing the old motherboard and installing a new one.
Wat je nodig hebt
Remove the two screws on the right side of the camera and the two screws on the left side.
Use a small #00 Phillips flat head screwdriver.
Keep all the screws in a container and the two different types separate.
Één andere persoon heeft deze handleiding voltooid.
