Ga door naar hoofdinhoud
Fujifilm FinePix Z1 Battery Replacement
  1. Fujifilm FinePix Z1 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the battery on the display screen of the camera is charged. If it is not fully charged, plug into charger and turn the camera on.
    • If the battery image on the display screen does not show then you will need to check the battery.
  2. Fujifilm FinePix Z1 Battery Replacement: stap 2, afbeelding 1 van 1
    • Turn the camera to the bottom and find the battery access door on the left side.
  3. Fujifilm FinePix Z1 Battery Replacement: stap 3, afbeelding 1 van 2 Fujifilm FinePix Z1 Battery Replacement: stap 3, afbeelding 2 van 2
    • Open the battery access door by pushing down and up on the spring-hinged door.
    • Check that there is no obvious damage or reason for a faulty battery.
  4. Fujifilm FinePix Z1 Battery Replacement: stap 4, afbeelding 1 van 1
    • Push the yellow tab to eject the battery.
  5. Fujifilm FinePix Z1 Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery and replace with a new one.
Conclusie
Carra
533 Reputatie
4 handleidingen geschreven
Baylor, Team S2-G4, Johnson Spring 2018 Lid van Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 20
Altijd: 732
