Ga door naar hoofdinhoud
Fujifilm FinePix XP80 Lens Replacement
Wat je nodig hebt
  1. Fujifilm FinePix XP80 Lens Replacement, Battery: stap 1, afbeelding 1 van 3 Fujifilm FinePix XP80 Lens Replacement, Battery: stap 1, afbeelding 2 van 3 Fujifilm FinePix XP80 Lens Replacement, Battery: stap 1, afbeelding 3 van 3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Lens Replacement: stap 2, afbeelding 1 van 1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Lens Replacement, Exterior Case: stap 3, afbeelding 1 van 1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Lens Replacement: stap 4, afbeelding 1 van 1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Lens Replacement: stap 5, afbeelding 1 van 1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Lens Replacement: stap 6, afbeelding 1 van 1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Lens Replacement: stap 7, afbeelding 1 van 1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Lens Replacement: stap 8, afbeelding 1 van 1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Lens Replacement: stap 9, afbeelding 1 van 2 Fujifilm FinePix XP80 Lens Replacement: stap 9, afbeelding 2 van 2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Lens Replacement, Interior Case: stap 10, afbeelding 1 van 1
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Lens Replacement: stap 11, afbeelding 1 van 1
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Lens Replacement: stap 12, afbeelding 1 van 1
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Lens Replacement: stap 13, afbeelding 1 van 3 Fujifilm FinePix XP80 Lens Replacement: stap 13, afbeelding 2 van 3 Fujifilm FinePix XP80 Lens Replacement: stap 13, afbeelding 3 van 3
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Lens Replacement: stap 14, afbeelding 1 van 1
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 Lens Replacement, Lens: stap 15, afbeelding 1 van 1
    • Using a plastic opening tool, remove the entire lens housing.
    • Install the new lens and housing (it is replaced as a single unit).
Conclusie
Amanda Lewis
317 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-3, Cagle Fall 2016 Lid van USF Tampa, Team 1-3, Cagle Fall 2016
USFT-CAGLE-F16S1G3
5 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 18
Altijd: 1,526
