Ga door naar hoofdinhoud
Fujifilm FinePix XP70 Front and Back Panel Replacement
Wat je nodig hebt
  1. Fujifilm FinePix XP70 Front and Back Panel Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Front and Back Panel Replacement: stap 2, afbeelding 1 van 2 Fujifilm FinePix XP70 Front and Back Panel Replacement: stap 2, afbeelding 2 van 2
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Front and Back Panel Replacement: stap 3, afbeelding 1 van 1
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Front and Back Panel Replacement, Front and Back Panel: stap 4, afbeelding 1 van 1
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  5. Fujifilm FinePix XP70 Front and Back Panel Replacement: stap 5, afbeelding 1 van 1
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  6. Fujifilm FinePix XP70 Front and Back Panel Replacement: stap 6, afbeelding 1 van 1
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  7. Fujifilm FinePix XP70 Front and Back Panel Replacement: stap 7, afbeelding 1 van 1
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  8. Fujifilm FinePix XP70 Front and Back Panel Replacement: stap 8, afbeelding 1 van 2 Fujifilm FinePix XP70 Front and Back Panel Replacement: stap 8, afbeelding 2 van 2
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  9. Fujifilm FinePix XP70 Front and Back Panel Replacement: stap 9, afbeelding 1 van 1
    • Lift off the front plate.
  10. Fujifilm FinePix XP70 Front and Back Panel Replacement: stap 10, afbeelding 1 van 3 Fujifilm FinePix XP70 Front and Back Panel Replacement: stap 10, afbeelding 2 van 3 Fujifilm FinePix XP70 Front and Back Panel Replacement: stap 10, afbeelding 3 van 3
    • Pry the back plate off with a plastic opening tool
Conclusie
Olivia A
484 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S7-G3, Julie Spring 2017 Lid van UMass Dartmouth, Team S7-G3, Julie Spring 2017
UMASSD-JULIE-S17S7G3
4 Leden
12 handleidingen geschreven
Één opmerking
Very helpful, do you know if you can buy these parts? I need the back part of the camera.
thank you
jg
Jose Gerardo Hernandez Montiel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 389
