Inleiding
In order to keep your camera functioning properly, and working battery is vital. A dead or drained battery will prevent the camera from turning on, taking photos, using flash, etc. Replacing the battery or removing for charge is quick and simple.
Wat je nodig hebt
Slide the lower silver tab labeled "1"down.
Slide the upper silver tab labeled "2"down. Once the second tab is flipped, the door will spring open.
Één opmerking
Hi Catherine,
Could you direct me to where I could buy a replacement battery door for the XP…exactly the same used in your video.
Many Thanks
Robert
