Ga door naar hoofdinhoud
Fujifilm FinePix XP10SE Rear Control Panel Replacement
Wat je nodig hebt
  1. Fujifilm FinePix XP10SE Rear Control Panel Replacement, Front Cover: stap 1, afbeelding 1 van 3 Fujifilm FinePix XP10SE Rear Control Panel Replacement, Front Cover: stap 1, afbeelding 2 van 3 Fujifilm FinePix XP10SE Rear Control Panel Replacement, Front Cover: stap 1, afbeelding 3 van 3
    • Use a screwdriver to remove the four screws from the top and bottom of the camera. Remove the screws securing the lanyard as well.
    • Use a T5 Torx bit to secure the exterior decorative cover of the device.
  2. Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 2, afbeelding 1 van 2 Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to detach the case.
  3. Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 3, afbeelding 1 van 2 Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to cautiously pry the casing off of the camera.
  4. Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 4, afbeelding 1 van 3 Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 4, afbeelding 2 van 3 Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 4, afbeelding 3 van 3
    • Carefully slide the case to the left. Avoid cracking the case on the lens.
  5. Fujifilm FinePix XP10SE Rear Control Panel Replacement, Lens: stap 5, afbeelding 1 van 1
    • Remove the screws from the lens cover
  6. Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 6, afbeelding 1 van 1
    • Remove the screws from the side metal cover of outer case.
  7. Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 7, afbeelding 1 van 2 Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 7, afbeelding 2 van 2
    • Gently remove the Lens from the housing.
  8. Fujifilm FinePix XP10SE Rear Control Panel Replacement, LCD: stap 8, afbeelding 1 van 1
    • Locate the securing tabs of the housing unit.
    • Using the spongerslowly work your way around the outside of the case using the sponging tool to pry open the case.
    • *** Take extreme caution when doing this being careful not to break the securing tabs of the housing.
  9. Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 9, afbeelding 1 van 1
    • Once the case is open locate the Ribbon cable attachment for the LCD screen.
    • Carefully ensure that the LCD screen is free from all attachments and any tape securing the ribbon cable is released.
  10. Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 10, afbeelding 1 van 2 Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 10, afbeelding 2 van 2
    • Gently lift up on the black securing bar of the ribbon cable in order to free it from the units motherboard, thus releasing the LCD from the computer.
  11. Fujifilm FinePix XP10SE Rear Control Panel Replacement, Rear Control Panel: stap 11, afbeelding 1 van 3 Fujifilm FinePix XP10SE Rear Control Panel Replacement, Rear Control Panel: stap 11, afbeelding 2 van 3 Fujifilm FinePix XP10SE Rear Control Panel Replacement, Rear Control Panel: stap 11, afbeelding 3 van 3
    • Locate the ribbon cable attachment for the rear panel controls.
    • Gently lift the ribbon cable securing bar and slide the ribbon cable from the socket in order to remove the rear control panel.
  12. Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 12, afbeelding 1 van 3 Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 12, afbeelding 2 van 3 Fujifilm FinePix XP10SE Rear Control Panel Replacement: stap 12, afbeelding 3 van 3
    • Locate the six screws on the control panel.
    • **two of the screws may be covered by tape. Remove the tape to access them.
    • Use the PH000 Phillip’s screwdriver bit from the Ifixit driver kit to remove the screws and free the control panel from the unit.
Conclusie
Bryan
598 Reputatie
5 handleidingen geschreven
Pasco Hernando, Team 5-1, Prince Winter 2015 Lid van Pasco Hernando, Team 5-1, Prince Winter 2015
PHSC-PRINCE-W15S5G1
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 132
