Ga door naar hoofdinhoud
Fujifilm FinePix T500 LCD Screen Replacement
Wat je nodig hebt
  1. Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 3 Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 2 van 3 Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 3 van 3
    • Unscrew the six 3.5mm Philips head from the outer casing.
  2. Fujifilm FinePix T500 LCD Screen Replacement: stap 2, afbeelding 1 van 3 Fujifilm FinePix T500 LCD Screen Replacement: stap 2, afbeelding 2 van 3 Fujifilm FinePix T500 LCD Screen Replacement: stap 2, afbeelding 3 van 3
    • Open the battery compartment and remove the battery.
    • Carefully pry the front half of the casing away from the camera.
    • Pay close attention to the sensor cover—a small piece of translucent plastic—as it may fall out of place. If it does, place it back in its original position.
  3. Fujifilm FinePix T500 LCD Screen Replacement: stap 3, afbeelding 1 van 2 Fujifilm FinePix T500 LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  4. Fujifilm FinePix T500 LCD Screen Replacement: stap 4, afbeelding 1 van 3 Fujifilm FinePix T500 LCD Screen Replacement: stap 4, afbeelding 2 van 3 Fujifilm FinePix T500 LCD Screen Replacement: stap 4, afbeelding 3 van 3
    • Lift the LCD screen out of the camera.
    • Locate the tab securing the ribbon cable that connects the screen to the motherboard. Using a spudger, gently lift the tab to release the ribbon. Carefully disconnect the screen from the motherboard.
Conclusie
George Lindner
252 Reputatie
2 handleidingen geschreven
USF Tampa, Team 19-3, Blackwell Winter 2015 Lid van USF Tampa, Team 19-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G3
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 684
