Inleiding
This is a guide for removing the case top of the Fujifilm FinePix S9500 camera. In order to replace parts on this camera, it is necessary to first remove the case top. This guide will provide instructions on how to do so.
Wat je nodig hebt
Locate and remove two screws. They are M1.7 x 5.0 in size.
The first screw is below and to the left of the command dial on the back of the camera.
The second screw is on the right side of the camera, to the right of the strap mount.
To open the case, gently push upward in the area just below the command dial with your thumb.
To release the catch located on the left of the command dial and at the base of the flash, place your thumb to the right of the command dial and push upwards at a 45° angle towards the flash.
