Ga door naar hoofdinhoud
Fujifilm FinePix S8200 Selector Replacement
Wat je nodig hebt
  1. Fujifilm FinePix S8200 Selector  Replacement, Batteries: stap 1, afbeelding 1 van 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Selector  Replacement: stap 2, afbeelding 1 van 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Selector  Replacement: stap 3, afbeelding 1 van 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: stap 4, afbeelding 1 van 3 Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: stap 4, afbeelding 2 van 3 Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: stap 4, afbeelding 3 van 3
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. Fujifilm FinePix S8200 Selector  Replacement: stap 5, afbeelding 1 van 3 Fujifilm FinePix S8200 Selector  Replacement: stap 5, afbeelding 2 van 3 Fujifilm FinePix S8200 Selector  Replacement: stap 5, afbeelding 3 van 3
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. Fujifilm FinePix S8200 Selector  Replacement: stap 6, afbeelding 1 van 1
    • Remove the rear housing cover by carefully pulling it away from the camera.
  7. Fujifilm FinePix S8200 Selector  Replacement, Removing Selection Button: stap 7, afbeelding 1 van 1
    • To Replace the Selection button, carefully pull the button until the button has been fully detached.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ugent Dailey
119 Reputatie
1 Handleiding geschreven
USF Tampa, Team 7-1, Remmell Winter 2015 Lid van USF Tampa, Team 7-1, Remmell Winter 2015
USFT-REMMELL-W15S7G1
4 Leden
9 handleidingen geschreven
Één opmerking
preciso dessa peça.. aonde consigo encontrar para comprar? email: smchous@hotmail.com
smchous - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 1,100
