Ga door naar hoofdinhoud
Fujifilm FinePix S4800 Electromagnetic Shield Replacement
Wat je nodig hebt
  1. Fujifilm FinePix S4800 Electromagnetic Shield Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 2, afbeelding 1 van 3 Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 2, afbeelding 2 van 3 Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 2, afbeelding 3 van 3
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
  3. Fujifilm FinePix S4800 Electromagnetic Shield Replacement, Rear Case: stap 3, afbeelding 1 van 1
    • Remove the three 5.0 mm JIS #000 screws on the bottom of the camera.
  4. Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 4, afbeelding 1 van 1
    • Rotate the camera so that the HDMI port is facing up.
    • Remove the two 5.0 mm JIS #000 screws.
  5. Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 5, afbeelding 1 van 1
    • Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
  6. Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 6, afbeelding 1 van 3 Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 6, afbeelding 2 van 3 Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 6, afbeelding 3 van 3
    • Press the pop-up button highlighted in the picture to release the flash mechanism.
    • Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
  7. Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 7, afbeelding 1 van 3 Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 7, afbeelding 2 van 3 Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 7, afbeelding 3 van 3
    • Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
    • The plastic case is fragile, so take your time on each side making sure to pry each side evenly as you continue around the camera with the tool.
  8. Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 8, afbeelding 1 van 2 Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 8, afbeelding 2 van 2
    • Gently, remove the rear case from the camera and set it aside.
  9. Fujifilm FinePix S4800 Electromagnetic Shield Replacement, LCD Screen: stap 9, afbeelding 1 van 3 Fujifilm FinePix S4800 Electromagnetic Shield Replacement, LCD Screen: stap 9, afbeelding 2 van 3 Fujifilm FinePix S4800 Electromagnetic Shield Replacement, LCD Screen: stap 9, afbeelding 3 van 3
    • At this point, it is highly recommended that you wear an ESD wristband to prevent damage to the internal electronic components.
    • With respect to the camera that was disassembled for this guide, the LCD display easily fell out of its housing after the rear case was removed. If your screen fits more tightly, you can use a plastic removal tool to gently pry up one of the edges of the screen and that will release it from its mount.
    • Gently tilt the LCD screen toward the bottom of the camera and use a spudger to flip the lock for the ZIF cable attached to the LCD.
  10. Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 10, afbeelding 1 van 1
    • Lift the screen away from the camera and set it aside.
  11. Fujifilm FinePix S4800 Electromagnetic Shield Replacement, Electromagnetic Shield: stap 11, afbeelding 1 van 1
    • Remove the four 4.5 mm JIS #000 screws.
    • The electromagnetic shield is attached onto the motherboard please proceed with caution when removing screws.
  12. Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 12, afbeelding 1 van 2 Fujifilm FinePix S4800 Electromagnetic Shield Replacement: stap 12, afbeelding 2 van 2
    • Gently pull the shield off the motherboard and set it aside.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Fanessa Jeune
303 Reputatie
2 handleidingen geschreven
USF Tampa, Team S19-G4, Hoffman Spring 2017 Lid van USF Tampa, Team S19-G4, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G4
4 Leden
16 handleidingen geschreven
Één opmerking
Bonsoir , j'ais besoin de schema power on jumper et declencheur de ce camera svp
samson Tsaravahizo Kalo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 21
Altijd: 459
