Ga door naar hoofdinhoud
Fujifilm FinePix S4800 Battery Replacement
  1. Fujifilm FinePix S4800 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 Battery Replacement: stap 2, afbeelding 1 van 3 Fujifilm FinePix S4800 Battery Replacement: stap 2, afbeelding 2 van 3 Fujifilm FinePix S4800 Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Stephen Calabrese
584 Reputatie
3 handleidingen geschreven
USF Tampa, Team S19-G4, Hoffman Spring 2017 Lid van USF Tampa, Team S19-G4, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G4
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 43
Altijd: 3,613
