Ga door naar hoofdinhoud
Fujifilm FinePix S4200 LCD Screen Replacement
Wat je nodig hebt
  1. Fujifilm FinePix S4200 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Turn the camera off.
    • Turn the camera upside down so that the battery compartment is showing.
  2. Fujifilm FinePix S4200 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 4 mm screws from the bottom of the camera with a Phillips #000 screwdriver.
  3. Fujifilm FinePix S4200 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Rotate camera to the side where the speaker ports are located.
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  4. Fujifilm FinePix S4200 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Turn the camera to the opposite side where the HDMI port is located.
    • Remove all five 4 mm screws with a Phillips #000 screwdriver.
  5. Fujifilm FinePix S4200 LCD Screen Replacement: stap 5, afbeelding 1 van 3 Fujifilm FinePix S4200 LCD Screen Replacement: stap 5, afbeelding 2 van 3 Fujifilm FinePix S4200 LCD Screen Replacement: stap 5, afbeelding 3 van 3
    • Casing is fragile.
    • Utilize the plastic opening tool to pry in between the back casing of the camera from the front casing.
    • Continue this motion around the camera to create a wedge between the front and back casing of the camera.
  6. Fujifilm FinePix S4200 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Use force to pull apart the back casing from the camera.
  7. Fujifilm FinePix S4200 LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 4 mm screws that hold the motherboard and metal plate in place.
  8. Fujifilm FinePix S4200 LCD Screen Replacement: stap 8, afbeelding 1 van 2 Fujifilm FinePix S4200 LCD Screen Replacement: stap 8, afbeelding 2 van 2
    • Utilize the plastic opening tool to gently lift the LCD screen away from the metal plate.
    • Flip over LCD screen so that the left side of the metal plate is visible.
  9. Fujifilm FinePix S4200 LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Rotate the camera vertically so that it is easier to manage.
    • Use a Phillips #000 screwdriver to remove the two 4mm screws that are located on the metal plate under the LCD screen.
  10. Fujifilm FinePix S4200 LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Detach the metal plate from the motherboard.
  11. Fujifilm FinePix S4200 LCD Screen Replacement: stap 11, afbeelding 1 van 2 Fujifilm FinePix S4200 LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • The orange ribbon cable is fragile.
    • Pull back the small black latch connecting the orange ribbon cable to the motherboard.
    • Gently remove the LCD screen from the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jackie Acevedo
340 Reputatie
2 handleidingen geschreven
CSU Fullerton, Team 1-4, Bruce Fall 2015 Lid van CSU Fullerton, Team 1-4, Bruce Fall 2015
CSUF-BRUCE-F15S1G4
4 Leden
7 handleidingen geschreven
1Gids Commentaar
Ou peut on trouver cet écran ?
lise.didion - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 33
Altijd: 1,691
