Inleiding
Outline what you are going to teach someone how to do.
Wat je nodig hebt
Use a PH0 screwdriver to remove four screws on the right side, three screws on the bottom, and four on the left side to take off the rear plate.
Remove the two screws from underneath the flash mechanism.
Remove the two screws placed on the right and left sides of the camera.
1Gids Commentaar
The solution I found here was to disassemble the camera as instructed in this manual until I reached the motor that drives the camera lens. I gradually injected voltage until the motor was activated and the lens worked. After the lens came out and moved, I put the camera back together.
GeekTeam - Tecnologia
