Ga door naar hoofdinhoud
Fujifilm FinePix HS30EXR Screen Replacement
Wat je nodig hebt
  1. Fujifilm FinePix HS30EXR Screen Replacement, Frame: stap 1, afbeelding 1 van 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Screen Replacement: stap 2, afbeelding 1 van 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Screen Replacement: stap 3, afbeelding 1 van 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Screen Replacement: stap 4, afbeelding 1 van 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
    That's a bit misleading it's a spring clip at the bottom of the hot shoe
    Colin Head - Antwoord
  5. Fujifilm FinePix HS30EXR Screen Replacement: stap 5, afbeelding 1 van 1
  6. Fujifilm FinePix HS30EXR Screen Replacement: stap 6, afbeelding 1 van 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Screen Replacement: stap 7, afbeelding 1 van 2 Fujifilm FinePix HS30EXR Screen Replacement: stap 7, afbeelding 2 van 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Screen Replacement, Screen: stap 8, afbeelding 1 van 1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Screen Replacement: stap 9, afbeelding 1 van 1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Screen Replacement: stap 10, afbeelding 1 van 1
    • Now that the ribbon cable is unconnected, pull away the frame to work on.
  11. Fujifilm FinePix HS30EXR Screen Replacement: stap 11, afbeelding 1 van 1
    • Flip the frame component so that the inside is now accessible.
    • With a screwdriver, unscrew all highlighted screws.
  12. Fujifilm FinePix HS30EXR Screen Replacement: stap 12, afbeelding 1 van 1
    • Flip the LCD Screen component so that the bottom half is now accessible.
  13. Fujifilm FinePix HS30EXR Screen Replacement: stap 13, afbeelding 1 van 1
    • Remove the LCD Screen component from its mount.
    • Turn the LCD Screen component so that the right side is now accessible.
  14. Fujifilm FinePix HS30EXR Screen Replacement: stap 14, afbeelding 1 van 1
    • The LCD Screen can now be removed from the LCD Screen Mount.
    • Carefully remove the LCD Screen, as it is attached by another ribbon cable.
  15. Fujifilm FinePix HS30EXR Screen Replacement: stap 15, afbeelding 1 van 1
    • To remove the LCD Screen, flip the switch on the ribbon cable's container that is closest to the ribbon cable (highlighted by the red circle).
    • Carefully remove the ribbon cable from its compartment, and remove the LCD Screen.
    • Position your new LCD Screen onto where the old one was removed from, and reattach the ribbon cable (ensure that the switch is now clamped down; a light tug should not dislodge the ribbon cable).
Conclusie
4 andere personen hebben deze handleiding voltooid.
Andrew Scouten
838 Reputatie
5 handleidingen geschreven
Baylor, Team S1-G2, Williams Fall 2018 Lid van Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Leden
12 handleidingen geschreven
2 opmerkingen
Ecran de rechange trouvé chez elecok.
Tuto testé, fonctionne aussi pour le Fuji HS20 EXR.
Bravo et Merci à Andrew et aux contributeurs
Bernard MRT - Antwoord
Thanks I have fixed the screen on my camera now it works perfect
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 31
Altijd: 2,795
