Ga door naar hoofdinhoud
Fujifilm FinePix HS30EXR Frame Replacement
Wat je nodig hebt
  1. Fujifilm FinePix HS30EXR Frame Replacement, Frame: stap 1, afbeelding 1 van 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Frame Replacement: stap 2, afbeelding 1 van 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Frame Replacement: stap 3, afbeelding 1 van 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Frame Replacement: stap 4, afbeelding 1 van 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Frame Replacement: stap 5, afbeelding 1 van 1
  6. Fujifilm FinePix HS30EXR Frame Replacement: stap 6, afbeelding 1 van 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Frame Replacement: stap 7, afbeelding 1 van 2 Fujifilm FinePix HS30EXR Frame Replacement: stap 7, afbeelding 2 van 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
Conclusie
Andrew Scouten
838 Reputatie
5 handleidingen geschreven
Baylor, Team S1-G2, Williams Fall 2018 Lid van Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 686
