Ga door naar hoofdinhoud
Fujifilm FinePix HS30EXR Discharge Flash Replacement
Wat je nodig hebt
  1. Fujifilm FinePix HS30EXR Discharge Flash Replacement, Frame: stap 1, afbeelding 1 van 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 2, afbeelding 1 van 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 3, afbeelding 1 van 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 4, afbeelding 1 van 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 5, afbeelding 1 van 1
  6. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 6, afbeelding 1 van 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 7, afbeelding 1 van 2 Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 7, afbeelding 2 van 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Discharge Flash Replacement, Motherboard: stap 8, afbeelding 1 van 1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 9, afbeelding 1 van 1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 10, afbeelding 1 van 1
    • Disconnect the ribbon cable.
  11. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 11, afbeelding 1 van 1
    • With the Phillips #00 screwdriver, remove all five screws.
    • Remove the metal casing.
  12. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 12, afbeelding 1 van 1
  13. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 13, afbeelding 1 van 1
    • Ensure the four ribbon cables are disconnected from the motherboard.
    • Be aware, one is under the black tape.
  14. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 14, afbeelding 1 van 1
    • Begin desoldering all four highlighted areas.
  15. Fujifilm FinePix HS30EXR Discharge Flash Replacement: stap 15, afbeelding 1 van 1
    • Remove the motherboard.
  16. Fujifilm FinePix HS30EXR Discharge Flash Replacement, Discharge Flash: stap 16, afbeelding 1 van 1
    • Remove the discharge flash by giving it a light tug. It is held in place with glue.
    • Replace the old flash bulb with a new one, and begin the reconstruction of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Haden Calvert
100 Reputatie
1 Handleiding geschreven
Baylor, Team S1-G2, Williams Fall 2018 Lid van Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 764
