Ga door naar hoofdinhoud
Fujifilm FinePix F505EXR Selector Button Replacement
Wat je nodig hebt
  1. Fujifilm FinePix F505EXR Selector Button Replacement, Battery: stap 1, afbeelding 1 van 2 Fujifilm FinePix F505EXR Selector Button Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power the device down before taking any other actions.
    • Hold the camera with the lens facing towards youself.
    • Turn the camera upside down and place your right thumb on the battery chamber cover.
  2. Fujifilm FinePix F505EXR Selector Button Replacement: stap 2, afbeelding 1 van 2 Fujifilm FinePix F505EXR Selector Button Replacement: stap 2, afbeelding 2 van 2
    • Hold the camera, then pull the battery chamber towards yourself with your right thumb.
    • Pull the cover entirely out and release it to reveal the battery.
  3. Fujifilm FinePix F505EXR Selector Button Replacement: stap 3, afbeelding 1 van 2 Fujifilm FinePix F505EXR Selector Button Replacement: stap 3, afbeelding 2 van 2
    • Locate the orange battery latch that holds the battery in place.
    • Use your finger to push the latch away from yourself to release the battery.
    • Remove the battery manually from the battery chamber.
    • Place the battery into a charger if it is dead.
    • Remove battery before performing any other repairs.
    • Replace defective battery if previous steps fail
    • Contact support on the Fujifilm website for further assistance
  4. Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button Circuit Board: stap 5, afbeelding 1 van 3 Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button Circuit Board: stap 5, afbeelding 2 van 3 Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button Circuit Board: stap 5, afbeelding 3 van 3
    • Remove four 2.5mm Phillips #1 screws on the bottom of the camera near where the camera mount attaches.
    • Remove two 5.1mm Phillips #1 screws on the left side of the camera relative to the LCD screen.
    • Remove two 5.1mm Phillips #1 screws on the right side of the camera relative to the LCD screen nearest to the mode wheel.
  5. Fujifilm FinePix F505EXR Selector Button Replacement: stap 6, afbeelding 1 van 2 Fujifilm FinePix F505EXR Selector Button Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Place the camera lens face down with the LCD screen face up on a flat surface, or hold it. Carefully lift the camera’s back cover approximately 1 inch.
    • Carefully lift the ribbon clamp connector back using the tweezers and remove the blue ribbon.
    • Do NOT pull on ribbon if the ribbon clamp connector still grasps the blue ribbon. This could cause severe damage to the ribbon.
    • If you are replacing the LCD monitor you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the LCD monitor repair guide.
    • If you are replacing the Mode Dial you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the Mode Dial repair guide.
  6. Fujifilm FinePix F505EXR Selector Button Replacement: stap 7, afbeelding 1 van 1
    • Remove the back of the camera case and place it on a flat surface with the selector button circuit board facing up.
    • Remove the three 3.5mm Phillips #1 screws located on the chip seen in the image.
  7. Fujifilm FinePix F505EXR Selector Button Replacement: stap 8, afbeelding 1 van 3 Fujifilm FinePix F505EXR Selector Button Replacement: stap 8, afbeelding 2 van 3 Fujifilm FinePix F505EXR Selector Button Replacement: stap 8, afbeelding 3 van 3
    • Lift the chip with tweezers to remove it from the other remaining components.
  8. Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button: stap 9, afbeelding 1 van 1
    • After the selector button circuit board is taken out. There will be a black rubber display for the front buttons, remove this.
  9. Fujifilm FinePix F505EXR Selector Button Replacement: stap 10, afbeelding 1 van 2 Fujifilm FinePix F505EXR Selector Button Replacement: stap 10, afbeelding 2 van 2
    • After taking the rubber button selector out, there will still be a circular metal selector button. This is what makes the camera delete pictures and do various tasks. Remove this and set aside.
  10. Fujifilm FinePix F505EXR Selector Button Replacement: stap 11, afbeelding 1 van 1
    • Finally replace the selector button with the new replacement.
Conclusie
Brittany Perkins
310 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S2-G6, Isaacson Spring 2017 Lid van UMass Dartmouth, Team S2-G6, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 306
