Inleiding
This guide will show you how to replace the Mode Dial on the camera if it has stopped working or if it is stuck and will not move.
Wat je nodig hebt
Hold the camera with the lens facing towards youself.
Turn the camera upside down and place your right thumb on the battery chamber cover.
Remove four 2.5mm Phillips #1 screws on the bottom of the camera near where the camera mount attaches.
Remove two 5.1mm Phillips #1 screws on the left side of the camera relative to the LCD screen.
Remove two 5.1mm Phillips #1 screws on the right side of the camera relative to the LCD screen nearest to the mode wheel.
