Ga door naar hoofdinhoud
Fujifilm FinePix F505EXR Battery Replacement
Wat je nodig hebt
  1. Fujifilm FinePix F505EXR Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Fujifilm FinePix F505EXR Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power the device down before taking any other actions.
    • Hold the camera with the lens facing towards youself.
    • Turn the camera upside down and place your right thumb on the battery chamber cover.
  2. Fujifilm FinePix F505EXR Battery Replacement: stap 2, afbeelding 1 van 2 Fujifilm FinePix F505EXR Battery Replacement: stap 2, afbeelding 2 van 2
    • Hold the camera, then pull the battery chamber towards yourself with your right thumb.
    • Pull the cover entirely out and release it to reveal the battery.
  3. Fujifilm FinePix F505EXR Battery Replacement: stap 3, afbeelding 1 van 2 Fujifilm FinePix F505EXR Battery Replacement: stap 3, afbeelding 2 van 2
    • Locate the orange battery latch that holds the battery in place.
    • Use your finger to push the latch away from yourself to release the battery.
    • Remove the battery manually from the battery chamber.
    • Place the battery into a charger if it is dead.
    • Remove battery before performing any other repairs.
    • Replace defective battery if previous steps fail
    • Contact support on the Fujifilm website for further assistance
Conclusie
Matthew Kilmonis
219 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S2-G6, Isaacson Spring 2017 Lid van UMass Dartmouth, Team S2-G6, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 990
