Ga door naar hoofdinhoud
Fujifilm FinePix A350 Battery Contact Replacement
Wat je nodig hebt
  1. Fujifilm FinePix A350 Battery Contact Replacement, Batteries: stap 1, afbeelding 1 van 3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: stap 1, afbeelding 2 van 3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: stap 1, afbeelding 3 van 3
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: stap 2, afbeelding 1 van 3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: stap 2, afbeelding 2 van 3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: stap 2, afbeelding 3 van 3
    • On the underside of the battery hatch, locate the single 3.0 mm screw connecting the battery contact to the hatch. Remove it using a Phillips screwdriver with a #0 bit.
    • Lift the contact from the end where the screw was located and pull away from the hatch to remove it.
Conclusie
Jaxon Cramer
1.045 Reputatie
9 handleidingen geschreven
Clemson, Team 6-4, Benson Spring 2016 Lid van Clemson, Team 6-4, Benson Spring 2016
CLEM-BENSON-S16S6G4
4 Leden
17 handleidingen geschreven
Één opmerking
It turned on after lifting up contact. Thank you, but we figured it out as I started to begin reading.
David Justin Laylon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 493
