Ga door naar hoofdinhoud
Fujifilm Endeavor 100ix Power Button Replacement
Wat je nodig hebt
    1. Fujifilm Endeavor 100ix Power Button Replacement, Outer Casing: stap 1, afbeelding 1 van 1
      • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Fujifilm Endeavor 100ix Power Button Replacement: stap 2, afbeelding 1 van 1
      • Locate the battery door.
      Vraag FixBot
      Voeg opmerking toe
    3. Fujifilm Endeavor 100ix Power Button Replacement: stap 3, afbeelding 1 van 1
      • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
      Vraag FixBot
      Voeg opmerking toe
    4. Fujifilm Endeavor 100ix Power Button Replacement: stap 4, afbeelding 1 van 1
      • Remove the battery from the camera by pulling the battery door outwards.
      Vraag FixBot
      Voeg opmerking toe
    5. Fujifilm Endeavor 100ix Power Button Replacement: stap 5, afbeelding 1 van 1
      • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    6. Fujifilm Endeavor 100ix Power Button Replacement: stap 6, afbeelding 1 van 2 Fujifilm Endeavor 100ix Power Button Replacement: stap 6, afbeelding 2 van 2
      • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    7. Fujifilm Endeavor 100ix Power Button Replacement: stap 7, afbeelding 1 van 1
      • Locate the film door latch located on the side of the camera.
      • Insert the spudger under the latch.
      • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
      • Pry the latch upward, applying force perpendicular to the camera.
      Vraag FixBot
      Voeg opmerking toe
    8. Fujifilm Endeavor 100ix Power Button Replacement: stap 8, afbeelding 1 van 1
      • Insert the flat edge of the spudger between the gold front casing and the black back casing.
      • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
      Vraag FixBot
      Voeg opmerking toe
    9. Fujifilm Endeavor 100ix Power Button Replacement: stap 9, afbeelding 1 van 1
      • Squeeze the camera by placing a thumb on the tab marked CE.
      • Pull the back half of the camera firmly away from the camera body.
      Vraag FixBot
      Voeg opmerking toe
    10. Fujifilm Endeavor 100ix Power Button Replacement: stap 10, afbeelding 1 van 1
      • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    11. Fujifilm Endeavor 100ix Power Button Replacement: stap 11, afbeelding 1 van 2 Fujifilm Endeavor 100ix Power Button Replacement: stap 11, afbeelding 2 van 2
      • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
      Vraag FixBot
      Voeg opmerking toe
    1. Fujifilm Endeavor 100ix Power Button Replacement, Power Button: stap 12, afbeelding 1 van 1
      • Look on the inside of the black back casing.
      • Locate the red, rubber power button.
      Vraag FixBot
      Voeg opmerking toe
    2. Fujifilm Endeavor 100ix Power Button Replacement: stap 13, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Using the tweezers, grab the red, rubber power button and pull it off the casing.
      • Discard the faulty power button.
      • Grab the new power button with the tweezers.
      • Put the power button into place by placing it where the old button was.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow the instructions from the "Disassembling Fujifilm Endeavor 100ix Outer Casing" guide in reverse order.
Eric Nicolai
679 Reputatie
6 handleidingen geschreven
Cal Poly, Team 13-5, Forte Winter 2011 Lid van Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
5 Leden
72 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 55
Altijd: 2,196
