Ga door naar hoofdinhoud
Fujifilm Endeavor 100ix Battery Door Replacement
Wat je nodig hebt
  1. Fujifilm Endeavor 100ix Battery Door Replacement, Battery Door: stap 1, afbeelding 1 van 1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Fujifilm Endeavor 100ix Battery Door Replacement: stap 2, afbeelding 1 van 1
    • Locate the battery door.
  3. Fujifilm Endeavor 100ix Battery Door Replacement: stap 3, afbeelding 1 van 1
    • Locate the latch on the battery door.
    • Use your finger pry to it open where it says "BATT."
  4. Fujifilm Endeavor 100ix Battery Door Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery from the camera by pulling the battery door outward.
  5. Fujifilm Endeavor 100ix Battery Door Replacement: stap 5, afbeelding 1 van 1
    • Locate and remove three black 3.80mm screws on the back of the black casing with the Phillips #00 screwdriver.
  6. Fujifilm Endeavor 100ix Battery Door Replacement: stap 6, afbeelding 1 van 1
    • Squeeze the camera placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  7. Fujifilm Endeavor 100ix Battery Door Replacement: stap 7, afbeelding 1 van 2 Fujifilm Endeavor 100ix Battery Door Replacement: stap 7, afbeelding 2 van 2
    • Locate and remove the 3.80mm screw that holds the plastic strip to the camera body with a Phillips #00 screwdriver.
    • The plastic strip will now come off the camera body.
Conclusie
Eric Nicolai
679 Reputatie
6 handleidingen geschreven
Cal Poly, Team 13-5, Forte Winter 2011 Lid van Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,851
