Inleiding
If your camera case has scratches or dents, it can be replaced by unscrewing the case of it. You need to take out some screws on the left side, right side and bottom part.
Wat je nodig hebt
Remove the two screws on the right side.On the same side there is USB connector, open that little door and unscrew the little screw inside of it.
Bijna klaar!
Conclusie
