Ga door naar hoofdinhoud
FujiFilm FinePix S4500 Flash Springs Replacement
Wat je nodig hebt
  1. FujiFilm FinePix S4500 Flash Springs Replacement, LCD: stap 1, afbeelding 1 van 1
    • Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
  2. FujiFilm FinePix S4500 Flash Springs Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 3.5 mm Phillips #1 screws in these locations on the bottom of the camera with a screwdriver.
  3. FujiFilm FinePix S4500 Flash Springs Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 3.5 mm Phillips #1 screws in these positions on the right side of the camera with a screwdriver.
  4. FujiFilm FinePix S4500 Flash Springs Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to separate the back panel from the camera on the left side.
  5. FujiFilm FinePix S4500 Flash Springs Replacement: stap 5, afbeelding 1 van 1
    • Use a plastic opening tool to separate the back panel from the camera on the bottom.
  6. FujiFilm FinePix S4500 Flash Springs Replacement: stap 6, afbeelding 1 van 2 FujiFilm FinePix S4500 Flash Springs Replacement: stap 6, afbeelding 2 van 2
    • Use a plastic opening tool to separate the back panel from the camera on the left side, then remove the back panel from the camera.
  7. FujiFilm FinePix S4500 Flash Springs Replacement: stap 7, afbeelding 1 van 1
    • Use a plastic opening tool to separate the LCD screen from the camera.
  8. FujiFilm FinePix S4500 Flash Springs Replacement: stap 8, afbeelding 1 van 2 FujiFilm FinePix S4500 Flash Springs Replacement: stap 8, afbeelding 2 van 2
    • Flip up the black tab holding the LCD ribbon wire in place and remove wire.
  9. FujiFilm FinePix S4500 Flash Springs Replacement, Flash Springs: stap 9, afbeelding 1 van 3 FujiFilm FinePix S4500 Flash Springs Replacement, Flash Springs: stap 9, afbeelding 2 van 3 FujiFilm FinePix S4500 Flash Springs Replacement, Flash Springs: stap 9, afbeelding 3 van 3
    • Remove the 3.5 mm Phillips #1 screws holding the top to allow access to the flash mechanism.
  10. FujiFilm FinePix S4500 Flash Springs Replacement: stap 10, afbeelding 1 van 1
    • Remove the top and use a screwdriver to remove the highlighted 2.7 mm Phillips #1 screws.
    • Remove the top cover of the flash.
  11. FujiFilm FinePix S4500 Flash Springs Replacement: stap 11, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the pins holding the flash mechanism in place. Tweezers may be required.
  12. FujiFilm FinePix S4500 Flash Springs Replacement: stap 12, afbeelding 1 van 1
    • Use a pair of tweezers to remove the flash mechanism springs , then replace with the new springs.
Conclusie
Vicente Rios
708 Reputatie
6 handleidingen geschreven
Cal Poly, Team 9-4, Banghart Winter 2017 Lid van Cal Poly, Team 9-4, Banghart Winter 2017
CPSU-BANGHART-W17S9G4
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 706
