Ga door naar hoofdinhoud
FujiFilm FinePix A340 Flash Unit Replacement
Wat je nodig hebt
  1. FujiFilm FinePix A340 Flash Unit Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 Flash Unit Replacement: stap 2, afbeelding 1 van 3 FujiFilm FinePix A340 Flash Unit Replacement: stap 2, afbeelding 2 van 3 FujiFilm FinePix A340 Flash Unit Replacement: stap 2, afbeelding 3 van 3
    • Remove five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 Flash Unit Replacement: stap 3, afbeelding 1 van 2 FujiFilm FinePix A340 Flash Unit Replacement: stap 3, afbeelding 2 van 2
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 Flash Unit Replacement, LCD Screen: stap 4, afbeelding 1 van 1
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 Flash Unit Replacement: stap 5, afbeelding 1 van 1
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 Flash Unit Replacement: stap 6, afbeelding 1 van 1
    • Push both blue switches away from the holding device to unleach lcd ribbon.
    • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 Flash Unit Replacement: stap 7, afbeelding 1 van 1
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 Flash Unit Replacement: stap 8, afbeelding 1 van 1
    • Now that everything has been disconnected from the board, remove LCD screen.
  9. FujiFilm FinePix A340 Flash Unit Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • Remove the two screws holding the circuit board down.
  10. FujiFilm FinePix A340 Flash Unit Replacement: stap 10, afbeelding 1 van 2 FujiFilm FinePix A340 Flash Unit Replacement: stap 10, afbeelding 2 van 2
    • Remove black sticky tape from circuit board and camera case.
  11. FujiFilm FinePix A340 Flash Unit Replacement: stap 11, afbeelding 1 van 2 FujiFilm FinePix A340 Flash Unit Replacement: stap 11, afbeelding 2 van 2
    • Gently pull the circuit board away from the front side of the camera.
    • Be careful when removing assembly as to not break any solder leads or damage lens assembly.
  12. FujiFilm FinePix A340 Flash Unit Replacement: stap 12, afbeelding 1 van 2 FujiFilm FinePix A340 Flash Unit Replacement: stap 12, afbeelding 2 van 2
    • Remove the logic board by pulling straight away from assembly.
  13. FujiFilm FinePix A340 Flash Unit Replacement, Flash Unit: stap 13, afbeelding 1 van 1
    • Locate the flash unit of the camera. It includes the camera's flash and a capacitor.
  14. FujiFilm FinePix A340 Flash Unit Replacement: stap 14, afbeelding 1 van 2 FujiFilm FinePix A340 Flash Unit Replacement: stap 14, afbeelding 2 van 2
    • Unsolder the flash unit at it's three points.
    • Be careful not to damage the circuit board or surrounding parts with the solder iron.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cody
47 Reputatie
4 handleidingen geschreven
Cal Poly, Team 7-11, Maness Spring 2010 Lid van Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 17
Altijd: 3,906
