Ga door naar hoofdinhoud
Fugoo Tough XL Speaker Replacement
Wat je nodig hebt
  1. Fugoo Tough XL Speaker Replacement, Case: stap 1, afbeelding 1 van 1
    • Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
  2. Fugoo Tough XL Speaker Replacement: stap 2, afbeelding 1 van 2 Fugoo Tough XL Speaker Replacement: stap 2, afbeelding 2 van 2
    • Gently pull up and off the outer casing.
    • Do not feel afraid to use a bit of force if necessary.
  3. Fugoo Tough XL Speaker Replacement: stap 3, afbeelding 1 van 2 Fugoo Tough XL Speaker Replacement: stap 3, afbeelding 2 van 2
    • Remove the internal device from the outer casing.
    • Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
    • Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
  4. Fugoo Tough XL Speaker Replacement: stap 4, afbeelding 1 van 3 Fugoo Tough XL Speaker Replacement: stap 4, afbeelding 2 van 3 Fugoo Tough XL Speaker Replacement: stap 4, afbeelding 3 van 3
    • Use your hands to gently remove the side plates.
    • Use an opening tool to pry off the back plate with the Fugoo trademark.
  5. Fugoo Tough XL Speaker Replacement: stap 5, afbeelding 1 van 1
    • Slowly pull the front casing from the back casing. Avoid putting any tension on the connected cables.
    • Separate the two slowly and consistently to avoid damaging the speaker cables.
  6. Fugoo Tough XL Speaker Replacement, Speaker: stap 6, afbeelding 1 van 2 Fugoo Tough XL Speaker Replacement, Speaker: stap 6, afbeelding 2 van 2
    • Carefully untangle the wires that are connected from the speaker to the motherboard.
    • Using a tweezer, pull downwards on the base of each red speaker connector to remove them from the motherboard.
  7. Fugoo Tough XL Speaker Replacement: stap 7, afbeelding 1 van 3 Fugoo Tough XL Speaker Replacement: stap 7, afbeelding 2 van 3 Fugoo Tough XL Speaker Replacement: stap 7, afbeelding 3 van 3
    • Use a #3 Hex screwdriver to unscrew all six 3mm screws."
    • While holding the case with one hand, pull up on the speaker you wish to replace.
Conclusie
Abdul
527 Reputatie
4 handleidingen geschreven
USF Tampa, Team S19-G1, Hoffman Spring 2017 Lid van USF Tampa, Team S19-G1, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G1
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 989
