Ga door naar hoofdinhoud
Frosty Factory Model 113 Rubber Gasket Seal Replacement
  1. Frosty Factory Model 113 Rubber Gasket Seal Replacement, Rubber Gasket Seal: stap 1, afbeelding 1 van 1
    • We will be replacing the rubber gasket seal for this margarita machine.
    • The seal is the black ring seen in the photo.
  2. Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 2, afbeelding 1 van 3 Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 2, afbeelding 2 van 3 Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the white knobs that are on the four corners of the faceplate in diagonal pairs.
    • This will safely release the seal's pressure.
    • Place the knobs aside.
    • Pull the faceplate off the machine.
  3. Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 3, afbeelding 1 van 3 Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 3, afbeelding 2 van 3 Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 3, afbeelding 3 van 3
    • Remove the old seal from the faceplate.
    • It might be difficult to pull out if you have short nails.
  4. Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 4, afbeelding 1 van 3 Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 4, afbeelding 2 van 3 Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 4, afbeelding 3 van 3
    • Pull out the beater bar. This will make the reassembly easier.
    • Notice the beater shaft on the beater bar that attaches to the white faceplate bushing on the faceplate that the seal was on.
  5. Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 5, afbeelding 1 van 1
    • Place the new rubber seal in the frame.
    • It should slide in easily.
    • Here is the white faceplate bushing for front end of the beater bar to go into.
  6. Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 6, afbeelding 1 van 3 Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 6, afbeelding 2 van 3 Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 6, afbeelding 3 van 3
    • Slide the black carbon ring wrapped end of the beater shaft towards the slot in the machine's mixing chamber.
    • Carefully press the beater bar into the machine as far as you can once the black carbon ring end is in the slot.
    • Gently turn the beater bar clock-wise until the beater shaft catches the driver plate, which will allow you to push the bar closer to the back of the chamber's wall.
  7. Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 7, afbeelding 1 van 2 Frosty Factory Model 113 Rubber Gasket Seal Replacement: stap 7, afbeelding 2 van 2
    • Line the faceplate bushing up with beater shaft.
    • Align the faceplate's four outer holes along the four screws and push it against the machine.
    • Screw the knobs back on, once again in diagonal pairs.
    • If the beater bar does not let the face plate be pressed against the machine enough so that all four knobs can be reattached, then remove the face plate and re-adjust the beater bar to catch the driver plate.
Conclusie
You will have successfully disassembled, replaced, and then reassembled part of the machine.
Griffin Cadigan
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 250
