Inleiding
If your Frigidaire french door refrigerator Model number FFHB2750TD6 is telling you to replace the water filter then this is the guide for you. This fridge’s water filter plays a key role in filtering out your drinking water to ensure it is clean and safe for everyone. This fridge model, in particular, will notify you when your water filter needs replacement which brings a lot of ease to customers. Before beginning this guide be sure to turn off the ice maker and remove items located underneath the water filter. Water may leak out during replacement so removing items and placing a towel beneath the water filter makes for an easy clean-up.
On the right inner side of the fridge, you will find the model number.
Identifying the correct model number will ensure the proper purchase of the new water filter.
To turn the icemaker back on click the options button and hit the minus button, it will beep indicating it is back on.
To reset the water filter you hit the down arrow button beneath the options button and go down to "water filter".
Press and hold the set button above the minus button on the right side, it will then say "good" next to the water filter.
Press options again to return to the main screen.
