Ga door naar hoofdinhoud
Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement
Wat je nodig hebt
  1. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheels from Frame: stap 1, afbeelding 1 van 2 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheels from Frame: stap 1, afbeelding 2 van 2
    • Use the socket head of the 19mm wrench to unscrew the nut that connects the castor wheel’s fork to the steel frame.
    • Remove the wheel from the small steel frame.
  2. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: stap 2, afbeelding 1 van 3 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: stap 2, afbeelding 2 van 3 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: stap 2, afbeelding 3 van 3
    • Hold the bolt that connects the wheel to the fork with pliers.
    • This keeps the bolt through the wheel from rotating.
    • Use the socket head of the 10 mm wrench in your other hand to remove the nut on the other end of the bolt.
  3. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: stap 3, afbeelding 1 van 3 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: stap 3, afbeelding 2 van 3 Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: stap 3, afbeelding 3 van 3
    • Flip wheel over and remove the bolt.
    • Remove the castor wheel.
  4. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Obstructing Debris: stap 4, afbeelding 1 van 1
    • Check for and remove any debris from the wheel or wheel axel that may be obstructing motion.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alyssa Chaney
49 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-7, Maness Spring 2013 Lid van Cal Poly, Team 14-7, Maness Spring 2013
CPSU-MANESS-S13S14G7
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 1,398
