Ga door naar hoofdinhoud
Fountain Pen Nib Repair
Wat je nodig hebt
  1. Fountain Pen Nib Repair, Nib Repair: stap 1, afbeelding 1 van 3 Fountain Pen Nib Repair, Nib Repair: stap 1, afbeelding 2 van 3 Fountain Pen Nib Repair, Nib Repair: stap 1, afbeelding 3 van 3
    • Assess fountain pen nib damage. The nib is the small metal piece at the tip of the pen from which ink flows.
    • Practice caution when removing the nib, as it is sharp and may cut you.
    • Remove the nib by gripping its top with two fingers and pulling away from the body of the pen. Gently grip the top of the nib with your index finger and thumb. Pull the top away from the pen's body to remove the nib.
    • Removing the nib helps to better assess the fraying of the tines, which are the two thin pieces at the point of the nib.
  2. Fountain Pen Nib Repair: stap 2, afbeelding 1 van 2 Fountain Pen Nib Repair: stap 2, afbeelding 2 van 2
    • Press the nib of the pen down onto the flat surface.
    • Gently apply pressure to straighten out the nib.
    • Slowly roll the fountain pen nib horizontally, from left to right.
    • Rolling is the motion of pressing the nib down on a flat surface and moving it back and forth to straighten out any bends.
    • Rolling the nib of the fountain pen fixes flayed/separated tines.
  3. Fountain Pen Nib Repair: stap 3, afbeelding 1 van 1
    • Rotate the nib by 90 degrees.
    • Apply pressure in a style similar to Step 2. Continue to roll the nib, from the tip to base and back.
    • Rolling the nib after rotating it helps to repair bent tines.
  4. Fountain Pen Nib Repair: stap 4, afbeelding 1 van 1
    • Flip the pen over and repeat the process of Step 3.
  5. Fountain Pen Nib Repair: stap 5, afbeelding 1 van 2 Fountain Pen Nib Repair: stap 5, afbeelding 2 van 2
    • Be sure to practice caution when using sharp tools such as the knife!
    • Slide the knife, or thin metal surface, between the two tines on the nib.
    • Slowly move the pen nib up and down the length of the knife in a flossing motion.
    • This action can help correct misalignment.
  6. Fountain Pen Nib Repair: stap 6, afbeelding 1 van 1
    • Apply some simichrome polish onto a towel or rag.
    • Wax the entirety of the nib using the rag; try to avoid the body of the pen.
    • Removing the pen nib again may make this process easier for some fountain pens.
    • Polishing the pen nib helps to increase ink flow.
  7. Fountain Pen Nib Repair: stap 7, afbeelding 1 van 1
    • Allow the polish to dry before using the pen.
    • Optional: Using a dry chrome polishing rag, buff the pen nib to set the polish.
    • Your newly aligned pen is now ready to use!
Conclusie
6 andere personen hebben deze handleiding voltooid.
Clayton Braga
238 Reputatie
1 Handleiding geschreven
UC Davis, Team S2-G4, Andersen Winter 2020 Lid van UC Davis, Team S2-G4, Andersen Winter 2020
UCD-ANDERSEN-W20S2G4
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 55
Afgelopen 30 dagen: 253
Altijd: 14,996
