Ga door naar hoofdinhoud
Fosera Scandle 200 Motherboard Removal
Wat je nodig hebt
  1. Fosera Scandle 200 Motherboard Removal, Motherboard Removal: stap 1, afbeelding 1 van 1
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Motherboard Removal: stap 2, afbeelding 1 van 1
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Motherboard Removal: stap 3, afbeelding 1 van 1
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Motherboard Removal: stap 4, afbeelding 1 van 1
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Motherboard Removal: stap 5, afbeelding 1 van 1
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
Eindstreep
Vladislav Ignatov
585 Reputatie
3 handleidingen geschreven
USF Tampa, Team 12-5, Blackwell Fall 2014 Lid van USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 271
