Ga door naar hoofdinhoud
Ford Focus Door Interior dome light assembly Replacement
Wat je nodig hebt
  1. Ford Focus Door Interior dome light assembly Replacement, interior dome light: stap 1, afbeelding 1 van 2 Ford Focus Door Interior dome light assembly Replacement, interior dome light: stap 1, afbeelding 2 van 2
    • Remove the screw cover in the handle housing using a flathead screwdriver.
  2. Ford Focus Door Interior dome light assembly Replacement: stap 2, afbeelding 1 van 2 Ford Focus Door Interior dome light assembly Replacement: stap 2, afbeelding 2 van 2
    • Remove the screw that is holding the handle housing with a T20 Torx screwdriver.
  3. Ford Focus Door Interior dome light assembly Replacement: stap 3, afbeelding 1 van 2 Ford Focus Door Interior dome light assembly Replacement: stap 3, afbeelding 2 van 2
    • Carefully pull the handle housing off.
    • Do not pull too hard. There are wires attached to the back of the housing.
  4. Ford Focus Door Interior dome light assembly Replacement: stap 4, afbeelding 1 van 3 Ford Focus Door Interior dome light assembly Replacement: stap 4, afbeelding 2 van 3 Ford Focus Door Interior dome light assembly Replacement: stap 4, afbeelding 3 van 3
    • Detach the wires on the handle housing with a flathead screwdriver by pushing upwards on the release slot.
  5. Ford Focus Door Interior dome light assembly Replacement: stap 5, afbeelding 1 van 2 Ford Focus Door Interior dome light assembly Replacement: stap 5, afbeelding 2 van 2
    • Remove the cover on the door grip by prying gently with a flathead screwdriver.
  6. Ford Focus Door Interior dome light assembly Replacement: stap 6, afbeelding 1 van 2 Ford Focus Door Interior dome light assembly Replacement: stap 6, afbeelding 2 van 2
    • Take off the inside door panel by removing all screws with a T20 Torx screwdriver.
    • There are nine screws in total: two on the front, three on the outer side, two on bottom, and two on the inner side.
  7. Ford Focus Door Interior dome light assembly Replacement: stap 7, afbeelding 1 van 3 Ford Focus Door Interior dome light assembly Replacement: stap 7, afbeelding 2 van 3 Ford Focus Door Interior dome light assembly Replacement: stap 7, afbeelding 3 van 3
    • Pull the insulation back to access the door handle bracket.
    • Use an X-acto knife if needed.
  8. Ford Focus Door Interior dome light assembly Replacement: stap 8, afbeelding 1 van 3 Ford Focus Door Interior dome light assembly Replacement: stap 8, afbeelding 2 van 3 Ford Focus Door Interior dome light assembly Replacement: stap 8, afbeelding 3 van 3
    • Remove the two screws holding the handle bracket with a T20 Torx screwdriver.
  9. Ford Focus Door Interior dome light assembly Replacement: stap 9, afbeelding 1 van 3 Ford Focus Door Interior dome light assembly Replacement: stap 9, afbeelding 2 van 3 Ford Focus Door Interior dome light assembly Replacement: stap 9, afbeelding 3 van 3
    • Remove the outside door handle by prying gently with a flathead screwdriver to loosen, and then slide it back.
  10. Ford Focus Door Interior dome light assembly Replacement: stap 10, afbeelding 1 van 3 Ford Focus Door Interior dome light assembly Replacement: stap 10, afbeelding 2 van 3 Ford Focus Door Interior dome light assembly Replacement: stap 10, afbeelding 3 van 3
    • Detach the door latch rod from the handle bracket by pulling the plastic end out of the metal loop.
  11. Ford Focus Door Interior dome light assembly Replacement: stap 11, afbeelding 1 van 2 Ford Focus Door Interior dome light assembly Replacement: stap 11, afbeelding 2 van 2
    • Pull the locking rod free from the handle bracket and remove the broken handle bracket.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Cassidy
241 Reputatie
1 Handleiding geschreven
Michigan Tech, Team 1-11, Lauer Spring 2016 Lid van Michigan Tech, Team 1-11, Lauer Spring 2016
MTU-LAUER-S16S1G11
1 Lid
2 handleidingen geschreven
Één opmerking
Excellent guide. I should have watched the video before disassembly. Actually got part from coastal ford for $40. Same as napa but actual Ford part! And in stock. Thanks Glen
glenthomas784 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 92
Altijd: 23,057
