Ga door naar hoofdinhoud
FoodSaver V4980 Drip Tray Drawer Replacement
Wat je nodig hebt
  1. FoodSaver V4980 Drip Tray Drawer Replacement, Bottom Panel: stap 1, afbeelding 1 van 2 FoodSaver V4980 Drip Tray Drawer Replacement, Bottom Panel: stap 1, afbeelding 2 van 2
    • Use the PH2 screwdriver to remove the three 14mm Phillips Head screws.
    • Use a plastic opening tool to remove the rubber toppers, covering four more 14mm Phillips Head screws, and remove those screws with the same screwdriver.
  2. FoodSaver V4980 Drip Tray Drawer Replacement: stap 2, afbeelding 1 van 1
    • You may now carefully unhinge the bottom panel.
    • The bottom panel does not completely come off. There are many wires connecting the panel to the body of the machine, so be careful not to remove any of them on accident.
  3. FoodSaver V4980 Drip Tray Drawer Replacement, Drip Tray Drawer: stap 3, afbeelding 1 van 1
    • The drip tray should come right off. You may clean this afterwards and/or replace it, whichever is needed most.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Mackenzie Grossgold
940 Reputatie
6 handleidingen geschreven
Cal Poly, Team 34-17, Maness Spring 2016 Lid van Cal Poly, Team 34-17, Maness Spring 2016
CPSU-MANESS-S16S34G17
4 Leden
7 opmerkingen
I don’t need to replace the tray. I’m just trying to open it so I can clean it out. How can I open it? I pulled on the 2 tabs on the bottom and tried opening it but the tray will not open.
Jerry - Antwoord
You shouldn’t be pulling on any tabs. With the machine right side up there is a recess in the middle at the bottom that you can hook your fingers in. Then you can pull it out like a drawer.
scottthomas -
Same problem here. I followed the above directions and still I can not access the tray for cleaning.
Jeanniehow - Antwoord
This is the same procedure for the V4825 model in case anyone has that one.
scottthomas - Antwoord
You can completely remove the tray, but a couple additional steps are needed.
You need to slide the circuit board out. There is sufficient space to do so and it isn't fastened in place with screws or clips. You may need to clip the zip tie holding the wires and vacuum tubes to do so.
Once it is out, you can remove the 3 pin connector going to the tray sensor contacts. From there, remove the cable and the tray can finish sliding out for cleaning. It also gives better access for cleaning the top half of the vacuum chamber.
Reinstallation is opposite of removal. Make sure the sensor cable isn't getting pinched or bunched up when sliding the tray in/out before screwing the bottom back on.
Mark Dietz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 50
Altijd: 4,709
