Ga door naar hoofdinhoud
Foldable Shopping Cart Swivel Wheels Replacement
Wat je nodig hebt
  1. Foldable Shopping Cart Swivel Wheels Replacement, Swivel Wheels: stap 1, afbeelding 1 van 1
    • Clear out the area around the shopping cart and make sure it's free of any obstacles.
  2. Foldable Shopping Cart Swivel Wheels Replacement: stap 2, afbeelding 1 van 2 Foldable Shopping Cart Swivel Wheels Replacement: stap 2, afbeelding 2 van 2
    • Set up the shopping cart by laying it down with the back wheels on the floor.
    • While the method described here applies to most shopping carts, please be aware that not all carts may have the exact locking mechanism.
  3. Foldable Shopping Cart Swivel Wheels Replacement: stap 3, afbeelding 1 van 3 Foldable Shopping Cart Swivel Wheels Replacement: stap 3, afbeelding 2 van 3 Foldable Shopping Cart Swivel Wheels Replacement: stap 3, afbeelding 3 van 3
    • Remove a single wheel by pinching the locking mechanism and slide off the wheel with your hands.
    • You may use pliers instead of pinching the locking mechanism if its difficult or hard.
  4. Foldable Shopping Cart Swivel Wheels Replacement: stap 4, afbeelding 1 van 2 Foldable Shopping Cart Swivel Wheels Replacement: stap 4, afbeelding 2 van 2
    • Repeat the process in step 3 to remove the second wheel.
  5. Foldable Shopping Cart Swivel Wheels Replacement: stap 5, afbeelding 1 van 2 Foldable Shopping Cart Swivel Wheels Replacement: stap 5, afbeelding 2 van 2
    • This is how it should look with the wheels completely off.
  6. Foldable Shopping Cart Swivel Wheels Replacement: stap 6, afbeelding 1 van 3 Foldable Shopping Cart Swivel Wheels Replacement: stap 6, afbeelding 2 van 3 Foldable Shopping Cart Swivel Wheels Replacement: stap 6, afbeelding 3 van 3
    • Prepare the new wheels by ensuring the axle is clear from both sides.
    • Ensure the axle is closing in a bit on one end, as this will help lock it in.
  7. Foldable Shopping Cart Swivel Wheels Replacement: stap 7, afbeelding 1 van 2 Foldable Shopping Cart Swivel Wheels Replacement: stap 7, afbeelding 2 van 2
    • Slide the new wheel into the cart.
    • The clear end of the axle should be inserted first.
  8. Foldable Shopping Cart Swivel Wheels Replacement: stap 8, afbeelding 1 van 1
    • Insert the remaining wheel by repeating step 7.
  9. Foldable Shopping Cart Swivel Wheels Replacement: stap 9, afbeelding 1 van 2 Foldable Shopping Cart Swivel Wheels Replacement: stap 9, afbeelding 2 van 2
    • Ensure the wheels are securely locked, and check if you can move the car freely.
Conclusie
anthony s
196 Reputatie
1 Handleiding geschreven
2 opmerkingen
Where can I get these type of front swivel wheels to purchase?
Maria - Antwoord
Great tip! Thank you. How do you remove the back wheels? Thank you.
Dawn Campbell - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 61
Altijd: 167
