Ga door naar hoofdinhoud
FlySky FS-TH9X Joystick Replacement
Wat je nodig hebt
  1. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Disassembly: stap 1, afbeelding 1 van 1
    • On the back of the remote, you will see 6 5mm Phillips #2 head screws.
    • The six screws on the front of the remote are screws that disconnect the joysticks from the remote and cannot be used to remove the back panel.
  2. FlySky FS-TH9X Joystick Replacement: stap 2, afbeelding 1 van 1
    • Using a size two Phillips screwdriver, remove the six 5 mm Phillips #2 head screws
  3. FlySky FS-TH9X Joystick Replacement: stap 3, afbeelding 1 van 1
    • Using a pry tool with a little pressure, carefully pull apart the remote to expose the inside.
  4. FlySky FS-TH9X Joystick Replacement: stap 4, afbeelding 1 van 1
    • Continue to troubleshooting your device.
  5. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Joystick: stap 5, afbeelding 1 van 1
  6. FlySky FS-TH9X Joystick Replacement: stap 6, afbeelding 1 van 1
    • Carefully remove chassis from outer casing.
  7. FlySky FS-TH9X Joystick Replacement: stap 7, afbeelding 1 van 1
    • Gently remove wiring from circuit.
    • To replace this part please contact the manufacturer, or consult the internet, to purchase parts.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 19
Altijd: 177
