Ga door naar hoofdinhoud
FlySky FS-TH9X Antenna Wire Disconnected
Wat je nodig hebt
  1. FlySky FS-TH9X Antenna Wire Disconnected, FlySky FS-TH9X Antenna Wire Disconnected: stap 1, afbeelding 1 van 1
    • On the back of the remote, locate the antenna box labeled in red.
  2. FlySky FS-TH9X Antenna Wire Disconnected: stap 2, afbeelding 1 van 1
    • Unplug the wire that connects the antenna box to the controller.
  3. FlySky FS-TH9X Antenna Wire Disconnected: stap 3, afbeelding 1 van 1
    • On either side of the box, squeeze the clips and pull up to release the antenna box away from its socket.
  4. FlySky FS-TH9X Antenna Wire Disconnected: stap 4, afbeelding 1 van 1
    • Unscrew the two 2.5 mm Phillips #1 screws with a screwdriver and carefully remove the front plate.
  5. FlySky FS-TH9X Antenna Wire Disconnected: stap 5, afbeelding 1 van 1
    • Once you remove it, you will see a wire that is connected to the antenna, and a motherboard.
  6. FlySky FS-TH9X Antenna Wire Disconnected: stap 6, afbeelding 1 van 1
    • Locate the brass colored socket and the end of the wire and carefully connect them together.
    • It should click together.
  7. FlySky FS-TH9X Antenna Wire Disconnected: stap 7, afbeelding 1 van 1
    • Once connected assemble the box back together.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 122
