Ga door naar hoofdinhoud
Flute Head Cork Replacement
Wat je nodig hebt
  1. Flute Head Cork Replacement, Head Cork: stap 1, afbeelding 1 van 3 Flute Head Cork Replacement, Head Cork: stap 1, afbeelding 2 van 3 Flute Head Cork Replacement, Head Cork: stap 1, afbeelding 3 van 3
    • Unscrew the Flute Crown.
    • Use pliers to grip the protruding screw and pull out the old cork.
  2. Flute Head Cork Replacement: stap 2, afbeelding 1 van 3 Flute Head Cork Replacement: stap 2, afbeelding 2 van 3 Flute Head Cork Replacement: stap 2, afbeelding 3 van 3
    • Use a razor blade to cut the glue around the base of the screw set up.
    • Use a razor blade to cut the glue around the removable washer at the top of the cork.
    • Use a razor blade to make two lengthwise cuts on opposite sides of the cork.
    • Break the cork off of the screw.
  3. Flute Head Cork Replacement: stap 3, afbeelding 1 van 3 Flute Head Cork Replacement: stap 3, afbeelding 2 van 3 Flute Head Cork Replacement: stap 3, afbeelding 3 van 3
    • Use a small paintbrush to brush on a layer of contact cement onto the bottom of the new cork and the bottom of the screw set up.
    • Let contact cement sit for a few minutes and then slide the cork down onto the screw rod glue side first.
  4. Flute Head Cork Replacement: stap 4, afbeelding 1 van 3 Flute Head Cork Replacement: stap 4, afbeelding 2 van 3 Flute Head Cork Replacement: stap 4, afbeelding 3 van 3
    • Use a small paintbrush to paint a layer of polyurethane glue onto the top of the cork.
    • Do not use contact cement for this step because it will bind on contact and the washer needs to be screwed on.
    • Screw the washer onto the screw rod.
    • Wait for all the glues to dry.
  5. Flute Head Cork Replacement: stap 5, afbeelding 1 van 3 Flute Head Cork Replacement: stap 5, afbeelding 2 van 3 Flute Head Cork Replacement: stap 5, afbeelding 3 van 3
    • Drop the new cork and screw set up screw first into the bottom of the head joint. If the cork is the correct diameter you should be able to see it partially through the embouchure hole.
    • Flute head joints have a tapered diameter that is smaller at the top. This will not work if the cork is put into the top of the head joint.
    • Use the flute tuning rod to push the cork into the head joint until the tuning line at the bottom of the rod is in the middle of the embouchure hole.
    • If the cork is difficult to push down, paraffin wax can be rubbed onto the cork to help lubricate it.
  6. Flute Head Cork Replacement: stap 6, afbeelding 1 van 2 Flute Head Cork Replacement: stap 6, afbeelding 2 van 2
    • Screw the crown back onto the screw set up and play the instrument to test that the new cork works.
Eindstreep
Zoe Bixler
133 Reputatie
1 Handleiding geschreven
Texas Tech, Team S3-G25, Cowan Spring 2021 Lid van Texas Tech, Team S3-G25, Cowan Spring 2021
TTU-COWAN-S21S3G25
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 54
Altijd: 1,328
